Is turbo 16G>20G turbo upgrade worth?
Hi everyone,
I'm asking about the upgrade kit for stock 8MR turbo.
Here in Thailand, there's an upgrade kit with EVO9 Turbo housing and 20G billet cost around 500usd
Is it worth the money? And will there be any problem with upgrade the turbo?
Also how many house power will gain?
Thanks!
Thanks!
^x2. I'd get a MHI compressor wheel, that's prebalanced/ weighed. Or a billet wheel from dependable manufacturer. Remember these wheels spin in excess of 100,000 rpms. The maker of the diffuser (or compressor cover), doesn't really matter as much..
Also I would read up a bit before you purchase the 20g upgrade. I remember people ran into surging issues when running this setup. I'll post links if I can find them.
Where do you find the better thrust washers (ie 2 holing holes and more surface area) and wider journal bearings? The only kit I've found is from Kamak turbo's. Is this the only supplier? Or do you know another place that sells these items.?
Thanks
I've been looking for the "upgraded" thrust washer and journal bearings for while now. I understand that FP has their own thrust washer design, which is proprietary. So I don't think they sell them, individually.
Thanks
Thanks
Mike: 20Gs don't surge much/at all hung off a TD05H, I'd be more than happy to run this combo without antisurge.
ohmohm: Checkout Snailturbo on eBay, have seen their billet 20Gs up close and they're of reasonable quality. Approx $365USD
how about this one?
http://www.ebay.com/itm/Turbo-Compre...a88383&vxp=mtr
or any suggestion about turbo upgrade? Now I'm running stock.
waiting for GSC S2 to arrive
I want at least 400whp on 95octain
Please advice
Thanks!
Please advice
Thanks!
It could be difficult to achieve 400whp with 95oct, you could use a water/meth injection kit. There is a dozen good turbo choices on the market, if you're looking for a near 20g sized turbo, I suggest the new BB FP Green. The Tomei 7960 is also a good turbo, a good bargain nowadays.
Kamak/Kinugawa parts are fairly reasonable quality. I have the td06sl2r 20g turbo running at 24psi, has been doing so for the last 10,000kms, no issues so far.
