Do twin disks clutches mushroom synchro rings and break synchro springs?
I was wondering if twin disks clutches on evo transmissions cause synchro rings to get mushroomed at the key ways area, and break syncro springs. Trying to figure out if this issue is only true on dsm transmissions. If issue does not exist on evo transmissions, then I would like to know why.
DSM transmission experience with twin disk clutch:
I just rebuilt my GSX transmission because the twin disk clutch killed synchro springs in 3rd/4th hub and 5th/reverse hub. Reverse/5th, 4th and 3rd double synchro rings were mushroomed. All the damage occurred within 1K miles of a very expensive rebuild service. This time I decided to rebuild the transmission by myself. Replaced reverse synchro and all broken springs, managed to modify all syncro rings by removing the mushroomed area and hope that the material removed will give enough room to mushroom withouth getting the synchro rings jammed in the hub. Assembled transmission with higher preloads. Pending to be tested.
I have spoken to numerous tuners before i had my twin disc installed and every single person told me the safest way to go is with a twin disc. I had an evo 8 with a stage 2 3 puck clutch and i ruined all of synchros and had to have a rebuild after 5k miles.
Was you clutch properly adjusted?
I ruined my 9 trans by not adjusting the clutch and it was dragging the clutch when shifting wich cause me to break my 4th and 5th gear synchros.
http://www.jackstransmissions.com/pa...kills-synchros
Dragging clutch burns synchros up and damages engagement teeth on the gears and sliders if forced into a gear, I did not have those issues.
The issue I described in my post was broken springs and mushroomed synchro rings. Here is what i am talking about:
http://www.jackstransmissions.com/pa...hrooming-rings
Note: I just rebuilt the transmission on my own and modified all synchro rings. Also, set tighter preloads on input/interm/output shafts because I feel they were on a loose side from a previous stage 4 build. I hope tighter preloads will reduce vibrations/harmonics coming from the crank.
Synchrotech
482
May 16, 2022 08:03 AM
Boostin Perform
Evo 'For Sale' Services
41
Feb 12, 2020 09:05 AM
Boostin Perform
EvoX 'For Sale' Services
38
Feb 12, 2020 07:58 AM
tsitalon1
47
Jan 15, 2017 07:55 AM
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
