The Best Throttle Body?
Im running a stock Manifold at the moment but will be switching to a ported stock Manifold and a BBK-Full. I was kinda leaning towards the MAP 70MM but i guess MILSPEC 70mm would be basically the same thing i only saw the 65mm on MAPs website. I just wanna get one that doesnt have any issues lol
Your tps was probably not setup correctly then.
Stock intake manifold I would only use a stock TB that is ported. They do not make a 70mm stock TB. Let's not spread false info. Skunk2 makes a 70mm TB and they are terrible.
If you use a aftermarket manifold then IMO stock ported or a boomba 75mm. I run a 75mm and it is been working wonderfully.
