What are my options for a center diff
Old Mar 24, 2013 | 04:49 PM
Jesussaves1's Avatar
What are my options for a center diff, whats the best out there and how good is the stock one. and what are the differences.
Old Mar 24, 2013 | 04:54 PM
CT9Asphixyation's Avatar
Is your car equipped with ACD? I personally chose to have T.R.E. rebuild and upgrade mine along with the addition of a Wavetrac unit. You can research Quaife vs Wavetrac if you wanna get into the technical stuff. What do you plan on doing with the car?
Old Mar 25, 2013 | 01:21 PM
Just a daily driver. Also off subject but my steering feels sloppy, a new oem rack and pinion is over 1k. Whats your thought on a rebuilt one?
Old Mar 25, 2013 | 01:58 PM
joseph143's Avatar
Center or front diff? Huge difference... I would guess the other guy meant his front since he tossed the bits in about wavetrac. If you have acd you can't upgrade your center. Only the RS can. I mean without a huge swap. And the duffs won't help steering IMO. What you aught to look at is rack bushings, tie rod ends, and basically anything white line sells... That will stiffen the steering up. My car handles amazingly well...
420a-t's Avatar
I have a stock rack that needs new seals I'll sell for cheap if you need it
Old Mar 25, 2013 | 02:02 PM
joseph143's Avatar
For the record the center differential, the one that splits power front to rear is inside the transmission. Any changes to it will destroy your acd. The front diff which splits power to the front left/right wheels is inside the transfer case ironically. Anyway I'm going to unsub. If you have question pm me
Old Mar 25, 2013 | 02:30 PM
kikiturbo's Avatar
keep the ACD, have the ACD ecu reflashed, and tighten up the rear diff. job done..
Old Mar 25, 2013 | 02:32 PM
STiKillerr's Avatar
keep the ACD
Old Mar 25, 2013 | 03:14 PM
flyingscot's Avatar
ive been looking into center diff options too and there is not a lot out there,there used to be the gsc 40/60 but they dont make that anymore im told
Old Mar 25, 2013 | 09:44 PM
joseph143's Avatar
Cusco makes one still... 1.8-2k... But you get a solid torque split...
Old Mar 26, 2013 | 04:09 PM
so i guess if my center diff is trash i need to get a oem replacement?
Old Mar 27, 2013 | 01:40 AM
kikiturbo's Avatar
how do mean, trash?
foxbat
Mar 6, 2013 07:59 AM
KOOLER
Jan 24, 2013 03:44 PM
blowngasket
Jan 15, 2013 06:58 AM
crcain
Mar 27, 2008 02:14 PM
neonhero
17
Apr 13, 2004 05:04 PM
Quick Reply: What are my options for a center diff
