Front 02 Sensor Normal Voltage Range?
So I am looking for the expected normal voltage range for my Evo 8 on the front 02 sensor. The car is down on gas mileage, seems very boggy, and sounds different. Long story short I am trying to find some specs on the OEM upstream sensor, so I can troubleshoot it before I try changing it. I have observed some odd looking waveforms on the scan tool. Any help would be great.
if the fuel trims are slow to respond when you first start the car in the morning, or when in closed loop, the AFR's go super rich to super lean for longer periods of time, then most likely your front O2 sensor is failing.
A quick check would be to enable the rear o2 sensor with a test pipe or high flow cat. If you DO NOT get a CEL (within a reasonable amount of time) then your front sensor is failing. This was how I found my bad sensor.
The car is surging horribly during cold starts ( I let the car warm up for a minute or so and then drive off, and it still surges at parking lot speeds). Two minutes down the road the car will clean up a little, but still feels noticeably "off". When you get into boost hard it seems like the car is fine. My issues are mostly part throttle and during spool.
I'm going to take a much closer look at the fuel trims and voltages today. I would put a test pipe in, but I am fairly sure the rear 02 is being ignored by the car after being tuned.
So it would appear that my 02 sensor will not hit .9 volts on the high side of the wave, and the cross counts are pretty slow. I compared them to the upstream 02 sensors on my girls Outlander, and her sensor fires way faster, and peaks right around .9 volts when warm at cruising speeds. At this point I am going to replace the sensor and report back. I hope this resolves my issues.
Sorry to jack your thread..
I have the same issue, and I bought an OEM replacement sensor. Although when I came to replace it, I noticed that the plug on the vehicle harness is none existent, so I'm not sure which color of the vehicle harness matches the sensor plug.
Can anyone please have a look at their front o2 sensor and tell me what color from car harness matches with sensor plug.
Thank you and sorry once again.
I am having it done today, if I get a chance I will get in there and snap some shots of the harness.
This has been such a pain to find a resolution for........sooooooooooooooo many dead end threads where people just abandon them and leave them hanging.
Anyway just please let me know know once you get that pic !!! I'd really appreciate it
So I tried getting it out today. Took the radiator out, put a nice size socket on it, and nothing. I had to abort mission out of fear of stripping threads on the o2 housing as I do not have a replacement and this is my dd. I will have to fight this battle another day, super frustrating. May order an o2 housing before I attempt this again.
Can ANYONE please juste look at their Front o2 sensor car harness and confirm what color from car harness matches with sensor harness.
I've tried to search and can't find anything.
Sorry man I haven't been ignoring you, just mega busy. My cover is off my car, I can snap some pics tonight and text them to you worse case scenario.
On a side note I am now 100% sure that my trailing 02 sensor is outputting .80 or so at idle, and cruise conditions, which I am taking as the car running rich.
