oil leak after motor install
I just put a motor n in my car w the help of a friend on the weekends. Just ironning out the bugs and driving it a lil bit but I'm still getting oil from somewhere between the block n the hot side of the turbo. The turbo is dry but the o2 housing n everything else is dirty. It seems more like a spay, n my thoughts are the flex line that returns oil to the block may have a crack. My next step is to pull the down pipe, drain the oil, n check the line.
Wondering if anybody can give their .02¢
Nothing is leaking from them. We used the red gasket stuff for the feed line.
I know what I think it is but like I said, I'm a novice.
I just want to hear other possibilities that I may be overlooking...
I know this may seem obvious but we just dropped an engine into one and noticed oil all over the same areas you were describing. During the swap we forgot to put the inspection bolt on the block for the oil pump back in and was spraying oil all over the place.
It was a bolt hole in the front of the motor. The motor I got didn't come with one n we looked over it.
I'm slowly upping the boost keeping an eye on anything getting wet/leaking and breaking in my clutch.
After 7 weeks if not driving it, it feels really calming to drive it again.
Biggy VIII
Aug 9, 2016 03:06 PM
Braydo25
Lancer Aftermarket Forced Induction Tech
15
May 1, 2015 01:59 PM
