Twin plate clutch whining noise
Does anyone else with a Cusco (or even an Exedy/HKS) twin plate clutch experience any kind of whine while the clutch is engaging?
It happens only when I'm letting the pedal out relatively slowly and I can prevent it if I rev a little higher before letting the pedal out and/or letting the pedal out more quickly.
There's no judder or anything during the whine, it sounds like some kind of resonance - sorta like the brake pad squeal you get with aftermarket pads when you don't shim them.
(I have posted about this in a few other clutch threads but it was kinda off-topic so I'm reposting)
Thanks for any ideas.
I've got it too, happens when I down shift 4-3 and 3-2. When I rev match it doesn't do it. Although it did stop for a while, heated the clutch up some during a snow storm
, it didn't make the noise for like a month, it just recently started doing it again. I've also posted this a while back. EVO is stock.
![Devil](https://www.evolutionm.net/forums/images/smilies/devillook.gif)
, it didn't make the noise for like a month, it just recently started doing it again. I've also posted this a while back also. EVO is stock.
Originally posted by ez76
Space Monkey - what is it that makes that noise?
nefariousdeeds
11
May 17, 2013 12:56 AM
blackbichGSX
11
Aug 7, 2007 04:50 PM
