Crankshaft, nitrate or billet?
Well after performing some research on the process and what to do with my build, I sent my crank out to get nitrated and knife edged. The knife edge process that I am doing is not what you would think. This is just cleaning up the edge of the counter weights. This is not machining the crank weights to a point. I will post pics once its done.
However, I have had the last few crankshafts nitrated to case harden the crank. I have not had any issues with perfming this to my stock evo crank and now Im doing it to my 2.4L crank.
Has anyone else done this? Any engine builders out there that recommend or do not recommend it?
I had them quote making a billet crank and it was $2500.
Ive seen the ones on ebay and what not go for $1000 all the way up to $3500. I know the manley/eagle ones are made in China. Im not sure about the cosworth ones.
Does anyone use a billet crank? What brand and any issues in quality?
nitriding (not nitrating) infuses nitrogen into the surface of the crankshaft, and the nitrogen combines with carbon to make carbo-nitrides. the process not only hardens the surface (carbo-nitrides are very hard) but also creates a compressive layer in the plane of the surface. this compressive layer can improve fatigue crack nucleation resistance and is the real benefit of nitriding. the greater hardness has no benefit because a properly heat treated crank is already way harder than the journal bearings that support it.
with a stock crank if you damage the bearings and hear any audible noise the crank will no longer be round. with a nitrided crank you can swap bearings in car and be on your way again. the difference in hardness is remarkable.
I would disagree with statement in bold. i have been nitriding 7 bolt cranks for over ten years. 7 bolts no matter what the year has NO surface hardening from factory at all. nitriding drastcally reduces crankwalk and spun bearings.
I was cusious of how many builders do this or even recommend it to their customers if they are a shop.
Does anyone know if Buschur, MAP, AMS, or English Racing does this?
To what extent is magnafluxing (MPI ) still considered an important testing process that should be carried when selecting a used factory crank for a 2.3L, or 2.4L motor build?
WTB[Northeast]: OEM Crank or Billet Crank
SloEvo12
Dec 20, 2015 05:54 PM
italianevo88
17
Oct 27, 2010 03:08 AM
DynoDude55
Evo 'For Sale' Engine Internals and Drivetrain
12
Feb 9, 2010 07:41 AM
Evo8Emperor
21
Nov 24, 2009 03:42 AM
