Oil jets hitting Wiseco pistons?
Those squirters weren't so important for a 70hp/L NA 4G64, but definitely are for a 200+hp/L turbo engine. Anyone would be wise to install squirters in an engine with that much or more specific output if that engine wasn't originally equipped, and many do.
As you have read most everyone on here said to bend them and measure for clearance. I decided to delete them. The Wiseco pistons are forged and made to handle high heat, the factory pistons are not, therefore they used oil jets to cool the factory pistons. I found bolts with short threads, copper washers and lock tight and torqued them to the same spec as the oil jets. The motor has been running for a few years now on 25+ psi with no issues. Blocking them also provides more oil to more crucial parts of the motor.
Bend them to clear. Do not delete them.
louiesevox
10
Oct 29, 2017 06:56 AM
1fast97gsx
Nov 4, 2016 01:10 PM
usacchamp
45
Mar 4, 2016 07:15 PM
