Which Manley Turbo Tuff I-beams for 4G63 100mm stroker?
Hello
I am building a 4G63 2.3 100mm stroker for my Early Evo 2 (DSM 7-Bolt) block.
I had 652 whp (Dynapack) and will now go for 700-800 whp. I rev to 8500 rpm max, and will trap in 4th at about 8300 rpm max I believe. I have decided to go for Wiseco 1400H.D. pistons and Manley Turbo Tuff I-beams. I can see there are "regular" and one there they states "Utilizes lighter weight straight beam design for stroker applications"
Will the regular ones fit my application or do I have to use the stroker version? It may sound like a stupid question as they already have a stroker version, but I would prefer the regular as I believe they are stronger. Normal weights 675g, stroker 637g. As it is the same material, I believe they must be weaker as they are lighter.
The Manley Turbo Tuff 300M I-beams are only available in one version and they does not write anything that they dont fit a stroker application...
Thanks
Thanks
A normal 4G63 100mm stroker will use 150mm rods with the offset pin height in the piston.
If you want the lighter weight and strength, go the Carrillos.
standard turbo tuff i-beam are more than enough for what you need. they are better than most rods out there, but are heavier also.
http://www.manleyperformance.com/sc/...g63_rods.shtml
you can get the stroker straight beam they are lighter then the other ones.
If you're looking for someone to get them from shoot me a email from email in signature.
I would not waste $ on the 300m's they are overkill. there are cars making 1000whp on the regular turbo tuff's.
STM Tuned
Evo 'For Sale' Engine Internals and Drivetrain
Feb 8, 2016 06:33 AM
FS[SouthEast]: Manley Ibeam turbo tuff rods with ARP2000's
hutch959
Jan 5, 2016 06:00 PM
hutch959
Nov 28, 2015 06:35 PM
tkrizzy3
Oct 6, 2015 06:27 AM
WTB[Northeast]: 156mm I beam rods, or full 2.4 build
O0oDC
Jan 21, 2015 03:42 PM
