Stock Location Plastic Fuel Tank
We had an unlucky ethanol issue past month
We don't have E85 off the pump here in Turkey and we buy the Ethanol and mix it ourselves (car has Haltech Ethanol Content Analyzer so we can do measure the E85)
We put it in the car, ran the car without any problems
Left the ethanol in the tank for 3 weeks
Started the car, realized a fuel pressure loss
Remove the fuel hanger to check the pumps and realized the filters were all filled up, and the whole interior of the tank had corrosion
Apparently there was an acidic chemical additive in the ethanol
Long story short, we need a new tank and we don't want to have the same problem again
1) We need the tank to be plastic
2) It needs to fit the stock location (we can use 2 seperate tank since we cannot find one piece that looks like the the oem one)
3) Top cap location don't matter since we can cut the metal underneath the rear seat to have an opening for it
I found a fuel tank from Summit Racing that will fit. It's dimension is 13'' x 13'' x 8''
Any other options that you can recommend?
What are my other options when upgrading from the oem tank and having the tank in the stock location??
Here is the tank I found:
http://www.ebay.com/itm/Summit-Racing-Drag-Race-Fuel-Cell-5-Gallons-Plastic-Black-290101-13-x13-x8-/390617417328?pt=Motors_Car_Truck_Parts_Accessories&hash=item5af29cc670&vxp=mtr
I had the same in-tank rust problem and decided that if reinstalling the tank was as much of a PITA as it was taking it out, it wasn't worth coating the inside nor buying a good, used one for no less than $240 for shipping alone. Sold off the whole fuel system and upgraded.
can you post some more info on what upgrade you did?
Click the link in my sig, the 1st post has pics of everything.
I used a 16 gallon Summit Racing plastic fuel cell in the trunk. Ran the AN lines to the hard lines under the car.
Fuel cell
RedHorse and Earl -8 AN fittings
Nylon braided AN hose
Fuelab inline filter
Walbro inline 255lph fuel pump
Summit Racing digital fuel gauge(OEM will no longer work with cell)
Fuel cell
94AWDcoupe
44
Nov 6, 2017 08:40 AM
CO_VR4
Oct 25, 2016 05:30 PM
TTP Engineering
60
Feb 24, 2010 09:53 AM
