Question about gauge and stock vacuum hose hose
My greddy 60mm boost gauge didn't come with a hose to replace the factory "short line" on the passenger side of the manifold. It works ok with the stock one spliced, but it looks as if it is going to pop from being stretched over the t splitter. What kind of hose should I use to replace the factory line?
This is what I did as well, but the greddy t splitter has ridges (so you don’t need zip ties), and stretches the stock hose to the brink of bursting. I don't want to be left stranded in the middle of nowhere because of a preventable vacuum leak. I was wondering if someone could recommend a better hose to use for the job, and where to get it.
Originally posted by jbrennen
Go to your local auto parts store and buy a 12" length of vacuum hose that matches the one you've spliced. Shouldn't cost more than a buck or two. Put it somewhere in the car. If the hose ever blows apart and can't be put back together, you've got a spare hose -- you'll lose your gauge functionality, but hey, it's just a quick fix until you can do it right.
