Bolt/stud size request intake manifold to head
Looking for the bolt size and thread pitch of the intake manifold to head bolts. Bottom row closest to transmission. On my talon and truck, this is a stud in the head. Nothing to compare this to.
Requesting pic of said bolt or stud, bolt size, and thread pitch.
Will be looking into installing a threaded insert to repair a stripped bolt hole.
Can anyone else get the information I'm asking? I see a few engine build pics, I don't ser any shots from the intake manifold side. A few people with a tap and die set. Judging from the link, I already know its the wrong bolt size, unable to determine if I can get a threaded insert for the oem size bolt hole to use a stud, and I can get a stud from the local machine shop.
No ordering needed, just need correct measurements, and pic with stud in the correct location.
Borrowed pic from another thread.
Bolt hole next to the egr port is the one that is stripped. I can see the two studs in this pic, so confirming the bolt hole next to the egr is 10x1.25? Also seems this bolt might be fine as is without repair as it doesn't seal intake ports to head, only egr to head.
TURBODAWG
10
Mar 17, 2018 04:04 AM
MR Turco
Automotosports - Illinois
Jan 16, 2009 06:58 AM
