Diagnosing My Transmission Issue
Ok here's the deal with it.
New clutch install in March of this year: Competition Stage 3.5 clutch, New OEM TOB, Fidanza Flywheel. Everything torq' to Spec!
New Xfercase fluid & Transmission fluid was put in at the time.
Transmission fluid: Redline MT-90 Is what I was recommended from 3 different forum venders.
The Issue: Ok with the car On, Push in the clutch, it will go into any gear easy as butter. If I let off the clutch, push it in again then try to go into other gears it is kind of hard to put it into gear the first time then easy again.
Driving, If I push the clutch in while driving it is also hard to get it into gear or if I cycle through gears it seems a little "Notchy" I guess would be the word. I do not get any gear lock out as I have ran to 7k rpms and shifted normally with no issue. It seems that anything outside of normal slow shifting it wants to catch but not grind.
I've checked to make sure all bell housing bolts are tight, Adjusted the clutch pedal and still nothing has changed.
Could this by due to the MT-90? Please any opinions would help I am trying to fix this because shifting while WOT is almost pointless when I have to wait almost 2 seconds to shift.
Sounds like clutch drag. Check out this link..
http://www.jackstransmissions.com/pa...kills-synchros
couple of things to check before you drive it again.
I don't think it's "Locking" out of gear, My ACT clutch def had lock out and would "Grind" when trying to shift. This will still go into gear but it's making a pretty loud noise if I shift fast. & not the rear end noise, the noise I'm hearing is while the clutch is still pushed in which means I should hear Nothing.
I've read this and Tested everything it has listed with no luck.
I thought you mentioned some notchy-ness?
It's weird did not have these issue's with the OEM clutch, It was just slipping no issue's with gears. I put a brand new OEM TOB. I guess the clutch fork could be getting worn out but even with me having someone assist pushing the fork it's still not changing.
Though maybe the Transmission fluid isn't working with my transmission well or the shifter cables / bracket got bent on putting the transmission back in maybe?
I re-bleed it about 10 times yesterday. No air bubbles that I can see coming out.
When bleeding it does you guys clutch get stuck to the floor when holding it down and someone opens the bleeder?
Z_Lancer_Man
15
Mar 20, 2018 06:00 AM
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
nefariousdeeds
11
May 17, 2013 12:56 AM
millsyy17
17
Sep 5, 2011 12:22 PM
Solo II Evo
Apr 22, 2009 03:08 PM
