evo 9 MR not boosting over 10 psi
Old Aug 6, 2013 | 02:12 AM
Adi489's Avatar
I'm having problems with my evo not boosting over 10 psi. I ran a boost leak test and no leaks are found. vacuum lines going to the turbo are ok. check wastegate actuator and it works fine. help needed thanks
Old Aug 6, 2013 | 07:41 AM
chu's Avatar
chu
What are you using for a boost controller, and have you check it?
Old Aug 6, 2013 | 08:02 AM
joseph143's Avatar
Check your turbo shaftplay
Old Aug 6, 2013 | 07:49 PM
sparky's Avatar
Originally Posted by chu
What are you using for a boost controller.....?
Yeah, likewise, this is my first question.
Old Aug 6, 2013 | 08:39 PM
egis's Avatar
Or just disconnect the boost controller and see if you can boost to stock level.
Old Aug 7, 2013 | 07:29 AM
DropTheClutch's Avatar
Run it off wastegate pressure and see where that takes you
Old Aug 11, 2013 | 07:25 AM
Adi489's Avatar
I removed the vacuum line to the wastegate and the car overboosted to 1.5. so now, I left it how it came from the factory running off the wastegate and it runs at 0.8. is this stock boost on a evo 9 MR? it does hold the boost bc it doesn't drop, when I go full throttle it runs good is just that stops at 0.8! I don't have a boost controller. can anyone help me how to install a boost controller and what would you guys recommend for a good boost controller! my car is 100% stock the only mod is 3" exhaust all the way out, no cat. thanks for the ideas
Old Aug 11, 2013 | 07:30 AM
st0mp860's Avatar
That's odd. I've seen a lot of other members running a hallman or a grimspeed 3port.
Old Aug 11, 2013 | 07:31 AM
Adi489's Avatar
I removed the intake hose to check for play, I did feel a little play on the shaft but it doesn't move too much. the turbo is dry. no signs of oil anywhere in the turbo.
Old Aug 11, 2013 | 07:33 AM
Adi489's Avatar
quick question, what is the difference between a 2 port and a 3 port boost controller? I know is odd, I'm running out ideas
Old Aug 11, 2013 | 07:46 AM
st0mp860's Avatar
To be honest, I can't really answer your two posts after I responded. Still learning a lot myself, but I'm sure someone will be shining some knowledge on the subject soon enough.
Old Aug 11, 2013 | 09:08 AM
PureDrivePerformance's Avatar
A 3 port literally has 3 ports and it responds much faster. Are you tuned? What rom are you on?
Old Aug 11, 2013 | 03:58 PM
sparky's Avatar
This is what I would do too. You'll need a couple of feet of 4mm vacuum hose from the autoparts store. Disconnect the factory hose end that's attached to the j-pipe nipple, and the hose end attached to the WGA nipple. Stuff a golf "T" into each of the two open factory hose ends to prevent leaks.
Run a length of 4mm vacuum hose from the nipple on the WGA to the nipple on the j-pipe. Go for a WOT run in 4th gear and note the peak boost level achieved. I am guessing it is gonna be the same 10# that you are seeing.
Old Aug 11, 2013 | 04:47 PM
Adi489's Avatar
as far as the tuning to be honest I don't have any idea. the last owner said he had tuning done to the car. I have talk to a local tuner but he is out of town at this moment. I would like to know if my car has been tuned correctly.
Old Aug 11, 2013 | 04:50 PM
Adi489's Avatar
I did find a little leak at the throttle body shaft seals. but I dough this is my problem. I order the seals to be in the safe side. does anyone know what is the stock turbo boost supposed to be at?
