View Poll Results: Does your evo slap?
yes
12
7.84%
no
137
89.54%
only on cold starts
2.61%
Voters: 153. You may not vote on this poll
Piston Slap????!!!!!!
Old Feb 24, 2004, 06:09 PM
bluevilevo8's Avatar
Exclamation Piston Slap????!!!!!!
My car has mild piston slap. I can hear it even when it is fully warmed up. It is not very loud, but is there nonetheless. Is a little slap normal with the 4g63's? Oh, and please don't participate in the poll if you don't know what piston slap is, or if you have it.
Old Feb 24, 2004, 06:22 PM
matt55's Avatar
piston slap , you can hear that over injectors , ext , TOB.....?? what does it sound like , what is it ?
Old Feb 24, 2004, 06:31 PM
992gnt's Avatar
Only 4g63's with forged pistons and improper bore size would normally slap. If you have piston slap stock, I would think you have a problem. How many miles on the car? Mods?
Old Feb 24, 2004, 06:37 PM
SilverEvo8owner's Avatar
what the hell is piston slap?
Old Feb 24, 2004, 06:44 PM
Registered User
metaphysical's Avatar
It means the piston is "slapping" the sides of the cylinder walls. On some vehicles (LS1) the vehicles pistons will slap until fully "warmed" up...they expand with heat.
Old Feb 24, 2004, 06:49 PM
It's when the piston "slaps" against the bore because of a short piston skirt, or overbore. In extreme cases it sounds like a power stroke diesel. In my case, it sounds like faint dieseling. This is what my 02 camaro ss sounded like on a cold start. (click on play button) http://pistonslap.com/photos.htm
Old Feb 24, 2004, 06:54 PM
broeli's Avatar
It isn't piston slap. More than likely it is the lifters. It is normal
Old Feb 24, 2004, 06:57 PM
Believe me, I know what piston slap sounds like. My car slaps, period. I was wondering if any others have this.
Old Feb 24, 2004, 08:07 PM
dsm95hybrid's Avatar
What's the mileage? What kind of break in procedure did you use?
I seriously doubt that it's piston slap. You wouldn't often see that in a japanese (tight tolerences) motor that has a stock bottom end. The lifters are inheritantly noisy even though the design has improved over the years with larger oiling holes.
Old Feb 24, 2004, 08:18 PM
992gnt's Avatar
OMG that's horrible! My Eclipse slapped a little, but it was due to the high silicon content forged pistons and it was only audible when cold. If your Evo sounds anything like your Camaro, you've got some fubared bores. Straight to dealer with it!
Old Feb 24, 2004, 08:26 PM
It's not pronounced, but you can hear a "rattle rattle rattle rattle rattle rattle". This is starting to **** me off. My car has 1000 miles and more problems than I can count.
Old Feb 25, 2004, 07:47 AM
matt55's Avatar
r you sure that the " rattle rattle rattle rattle rattle rattle" is not the TOB? I would like to no more about this.
Old Feb 25, 2004, 08:17 AM
yes I'm sure
Old Feb 25, 2004, 08:21 AM
SuperchargedGTZ's Avatar
i know you know what piston slap sounds like, but you dont think it is the lifters do you?
I have really bad lifter clicking during a cold start up.
Old Feb 25, 2004, 08:27 AM
I have this too, as well as the noisiest injectors I've ever heard. i can hear the from 20 feet away with the hood popped. The noise I'm talking about is classic piston slap. It's a "shu shu shu shu shu" along with a "rattle rattle rattle rattle rattle". It's almost difficult to pick up over the injector noise, but you can hear it if you know what to listen for.
Quick Reply: Piston Slap????!!!!!!
