FP Cast Race Manifold for the 4G63
#377
Had mine coated, ported, and new bolts. It's going to be a tight squeeze with both bolts. They should have done the port job for free since there are a couple of the imperfections with the runners in the way of the two front bolts. I'm wondering how much room I have for a drill to make that cut within the runners for the bolt and tool to pass through.
#380
That is horrible fitment. I think they need to send those manifolds out with bolts that will clear their design. Possibly a allen type bolt or e-torx. those are usually used in tighter space areas. How the hell are you suppose to torque it down correctly?
#381
If everyone looks at FP's pics of the manifold in the OP, they went to town with a grinder on the front of the manifold so they could easily get to the 2 nuts. I don't know why they aren't doing this with the manifolds before they ship them out?!?
#382
This ^^ Obviously they knew about the problem from the get go. Why are they shipping them with out correcting it??
#384
I think a standard hex nut would of been better choice than the 12-pt ARP nut provided in the FP bolt kit. At least with a hex nut you can tighten/torque it with a open end wrench and crowsfoot.
Using a closed end wrench or socket on the ARP nut is a 'no go' without some grinding for tool clearance.
#386
