FP Cast Race Manifold for the 4G63
Old Jan 25, 2014 | 10:00 PM
  #526
Evotech8's Avatar
^Have you tested that casting void defect to see if it leaks thru a port runner wall??
I'd pour a little water or oil into that void to see if it's leaking thru a runner.
Old Jan 25, 2014 | 10:47 PM
  #527
honda-guy's Avatar
the void does not go through the runner, i would know since i'm porting the runners.
Old Jan 27, 2014 | 10:03 PM
  #528
JohnnyTSi's Avatar
This isn't much of an apples to apples comparison as there have been several significant changes to the car between these charts. This is the best comparison I could come up with. Both pulls were on straight 92 octane Chevron pump gas.
Before Cast FP manifold (this chart is a couple of years old):
After FP Cast Manifold install:
Changes to the car in between runs:
MAP open dump with external wastegate O2 housing (switched from an Invidia O2 housing)
Sparktech CDI COP kit (switched from OEM ignition)
FP Cast Manifold (switched from heavily ported OEM manifold)
Major mods are:
standard rod 2.4 block
ER ported head
S3 cams
Magnus cast intake manifold
FIC2150 injectors
ETS 4" intercooler and 2.5" IC pipes
BB FPBlack
ER SD tune
3" exhaust
I have both the internal wastegate and the external wastegate hooked up with only the external seeing signal from my controller (Hallman Pro). The combination does have a bit of a boost creep issue at lower boost levels. Unfortunately I had some technical challenges so we didn't get to complete an e85 pull like I had originally planned.
John-
Attached Thumbnails FP Cast Race Manifold for the 4G63-evo_524hp.jpg   FP Cast Race Manifold for the 4G63-evo568pumpdynochart.jpg
Old Jan 28, 2014 | 05:44 AM
  #529
SS1000RR's Avatar
I can't see the attached pics
Old Jan 28, 2014 | 07:03 AM
  #530
211Ratsbud's Avatar
Ditto
Old Jan 28, 2014 | 07:08 AM
  #531
aggieEVO's Avatar
Looking forward to this.
Originally Posted by Boosted Tuning
Ill be doing back to back testing on the dynojet tomorrow.....
Old Jan 28, 2014 | 07:19 AM
  #532
94AWDcoupe's Avatar
Old Jan 28, 2014 | 08:21 AM
  #533
JohnnyTSi's Avatar
Originally Posted by 211ratsbud
Ditto
for some reason the board lost the attachments, I've re-uploaded them.
John-
Old Jan 28, 2014 | 09:09 AM
  #534
Boosted Tuning's Avatar
The back to back testing got delayed a lil bit.
We went to the dyno and did a couple pulls to check the tune and the clients Tial BOV's valve got loose and came off the BOV and got sucked in to the engine (We didnt build or install the BOV on this car). It made it to the head, but didnt damage anything except for the BOV valve a lil bit.
So testing will be in a couple weeks, as the client and I have the next couple weekends scheduled with other stuff (client works all week and can only dyno on weekend.)
Ill post an update to this thread when I can. Sorry guys. I really wanted to do the first back to back, FP mani as the only change dyno test.
Old Jan 28, 2014 | 02:38 PM
  #535
Ralliart004's Avatar
Veteran: Air Force
Mine came in yesterday apparently I was customer # 60+ of 20 so I can better understand the delay now. It looks like a good solid piece and hopefully can get some back to back comparisons shortly.
Old Jan 30, 2014 | 12:53 AM
  #536
Monkey.Magic3's Avatar
What's the turn around time for these once ordered? is it still a fairly long wait?
Old Jan 30, 2014 | 07:04 AM
  #537
aggieEVO's Avatar
Wow, he got lucky.
Old Jan 30, 2014 | 02:59 PM
  #538
dsm nexus's Avatar
Wow, he got lucky.
Very!
Old Jan 31, 2014 | 12:19 AM
  #539
BkzProblem's Avatar
I wish fp or anybody for that matter would make a cast t3 exhaust manifold with an external wastegate..
Old Jan 31, 2014 | 04:52 AM
  #540
byt's Avatar
byt
Hafe had one but not sure if they're sill made these days
Quick Reply: FP Cast Race Manifold for the 4G63
