FP Cast Race Manifold for the 4G63
ace33joe (Apr 4, 2018)
#621
I regret not shaving some of the casting off near the front bolts before getting mine coated. Because I cant get a socket onto those. Have to use a wrench but the rad is right there... Will prob have to make some shorter socket or something.
ace33joe (Apr 5, 2018)
#623
how long ago did you buy your manifold? Has this been corrected on their casting mold?
2006EvoIXer (Apr 5, 2018)
High_PSI (Oct 21, 2020)
#628
I didn't back to back test it but its designed to be slightly larger then stock and it makes power. Even unported , I'm sure it played a role in the power I've made .
It also is less prone to cracking then a tubular manifold and preserves the cars sound. I think its a great choice for stock frame cars.
#629
The Arps snap. Never had an OEM break. Dsm forums cry about it too I guess.
@ForcedPerformance with such a nice manifold I would of made nice fasteners like I made from oem
#630
The ARPs are likely super strong in tension but because they are a hard steel, when locked up in the exhaust mani, they fail in rotation?
