Double Pumper 12v Wiring
where the heck do i run the power wire to the second pump? inside the car or outside?
i ran it underneath and tied it to the fuel lines. just doesnt seem like the smart thing to do so i took it all off and figured i'd consult you all
I used two conductor #12 stranded that is in a sheath to offer more protection. Use quality nylon tie straps [ black hides much better then clear or white ] to attach to the fuel line. It is a good idea to run an auxiliary ground to one of the pump housing attachment nuts along with the secondary pump ground. This also creates a more direct path for the main pump ground. Stereo shops have nice stranded two conductor sheathed wire.
darkknight
Feb 5, 2008 04:23 PM
Methodical4u
11
Sep 26, 2006 10:50 AM
NocturnalEVO
May 7, 2006 12:49 PM
