Fluids
#31
Originally posted by Shahul X
is it called Redline Shockproof light? anything else it would be called?
okay so I can get redline although I was thinking Amsoil....
TRANSFER case- shockproof light? .58 Liters
Rear diff Redline 75 w/90 w half a bottle of friction modifyer....sound good ?
-Shahul
-Shahul
Get the light. 75/90 NS in the rear....Make sure its NS. There is a difference. Use 4oz. of the friction modifier mixed with the qt. of diff fluid.
Then get 4 qts of Shockproof light for the x-fer case and tranny. It will take two people. Loads of fun....
#33
Originally posted by ErnieT
The exact fluid levels are in the back of your owners manual. The shockproof is in 3 different grades....1. heavy 2. Light 3. Extra light
Shockproof DOES come in the three types, and all are LSD compatible, so says Redline.
I guess how i read it is you suggesting purchase of a "Shockproof 75w-90NS" which isn't in the lineup.
ferb!
#34
I ran lightweight in my rear diff and it popped and chattered in low speed, tight turning situations. If you're going to use shockproof in the rear diff on your street-driven Evo, you need to add about 4oz. of the limited slip additive. I discussed this with a tech at Redline and that was what he suggested to do.
#35
Guys, read what I posted. I never said I put shockproof in the diff. I put Redline 75/90 NS with the friction modifier in the diff. I put the shockproof in the transfer case.
#36
so redline comes as a 75w90 and a 75w90 ns that needs a friction modifier.... whats the differance? and why wouldnt I just do the 75w90 w/o the modifier?
-shahul
-shahul
#38
-shahul
-shahul
-- OR --
You can run the NS and 'tune' the diff. Add more modifier until the chattering goes away.
ferb!
#40
oh, I just want somthing to help the diff and transfer since people are complaining about the transfer so much.....
I think I'll just do the 75w/90 redline
-Shahul
-Shahul
