SPAL FAL MISHIMOTO EBAY fans?
I need a proven fan setup to cool me down in stop and go traffic. The OEM fans will not fit with the T4 setup I am about to throw on, so I need a slim fan. After researching I have found a few threads that really left me still wondering what is the BEST setup. Obviously something with a shroud and the highest "true" 12v CFM will be best but some companies list different specs with their products. With that being said what have you tried? If you can list the part number and specs below it will keep this thread clutter free and maybe just listing a small description of what you use your EVO for and the temps if you log them.
ex.
Dual SPAL fans with shroud. PART # 12940837434
12 inch
1500cfm
I have used these fans for 2 years with no problems. My temps stay at 195 and never go higher or lower. I used the OEM fan switch and everything operates like it should from the factory. Something to note was the SPAL shroud fit perfectly on the OEM radiator and left me plenty of clearance for the tubular XX manifold.
Thanks again!
ex.
12 inch
1500cfm
Thanks again!
