Lifter Tick? Stock BOV Flutter?
Alright so I just got my evo ix, I bought it without knowing the history or what was/is in it. What I can see is a Perrin Fuel Rail (with what appear to be stock injectors), and an intake. When its running there is a noticeable tick coming from the engine. It's not a constant tick with a rhythm its an on/off tick that doesn't get louder as you rev but it does get slightly more fast paced. When I let off the gas (at idle) it remains the higher speed ticking for a couple seconds before dying down after the RPMs have already fallen.
The car drives normal but does feel lacking on power.
My next issue, when I boost the spool sounds ridiculously loud and more like air being sucked in than whine(maybe im just used to my wrx being quiet) and when I let off my BOV flutters everytime. I'm pretty sure the stock BOV isn't supposed to flutter so I'm wondering if I have another problem. Previous owner did have multiple gauges in the car, most taken out, with only a defi boost gauge left. Its also not connected.
I've also found a Blitz Dual SBC and an older Defi Advance Control Unit, both of which I disconnected. This is my first time modding a turbo car so I'm trying to learn as much as possible but I'd like to have the car running strong first.
Any help is much appreciated!
Sounds like maybe the vacuum line to the stock diverter valve maybe unplugged. I would check that. As for the ticking, when does it come on and go off? does it tick through the whole RPM range? or only certain spots? does it tick faster and louder with more throttle?
nspyr
26
Jun 20, 2017 02:08 AM
gik0geck0
19
Feb 20, 2012 06:12 AM
scottatyamaha
15
Oct 15, 2008 02:51 PM
