Mystery broken ball bearing found in oil pan
Hello,
I have been having a low rpm tick/slight knock and figured it was rod knock or lifter tick due to having cosworth m2 camshafts. I pulled the oil pan to check the rods and all of the rod bearings and cylinders are in excellent condition and are to spec, but i did find this in the oil pan:
any ideas what component this bearing goes to? i imagine the rest of it has been flushed out, and there were some small fragments of bearing race in the oil pump pickup as well.
any information or help on what needs to be changed would be extremely helpful.
thanks
thanks
I do not have an aftermarket turbo. stock evo 9 setup. The car runs fine with a weird ticking sound from the head/valve cover area. I just purchased the car and possibly it had an aftermarket ball bearing turbo on it at some point??
That's not very nice. If you still have the contact info from previous owner, I would question them in a calm manner of course, just find out the truth.
DANG! i was thinking so hard for a component that had ball bearings AND had access to the oil system, turbo was the only thing that made sense! i completely forgot about rocker arms, what about the black pieces, they seem like part of a bearing raceway though. can we get a pic of the size of the bearins, like compared to a penny or something?
I'm going to go with pieces parts from a BB turbo.... now you need to check everything to ensure there isn't more of that crap clogging up the feed or return lines as oil starvation would cause a nasty noise in the head.
