video on how to change clutch in a evo 8
Old Oct 5, 2013 | 10:09 AM
lavoy1's Avatar
hey guys i have a youtube channel with allot of honda videos but now that i own a evo im starting to add them to.. enjoy
http://www.youtube.com/watch?v=0-dLi...ature=youtu.be
Old Oct 5, 2013 | 12:43 PM
boostedwrx's Avatar
Nice video! Doesn't look like too much fun hehe. What stage comp clutch did you go with? Next mod should be getting rid of that RFL BOV
Old Oct 5, 2013 | 03:16 PM
SSMCL9's Avatar
perfect timing. thanks
Old Oct 5, 2013 | 04:36 PM
TBSE's Avatar
That is ALOT of work. Had no idea it was so complicated. I actually need to change the clutch on my car and was wondering how everything works. Looks like I will be going to a shop to get that done.
Old Oct 5, 2013 | 06:12 PM
sktng22's Avatar
i actually thought it looked easier then everyone makes it haha. good info
Old Oct 5, 2013 | 06:45 PM
barneyb's Avatar
Great video. I was driving my Evo around 30 minutes ago for the first time after replacing my clutch. So, having you show all those hard to reach bolts put a grin on my face.
When my throwout bearing wouldn't release I popped the wave clip instead. Same result.
After putting that little 0-ring in the place on the tc I found it in the oil dry under the car. So, I glued it in place.
I also made myself a gotcha. For some stupid reason I ended up removing four bolts from the rear mount. Two were gold and two were green, same size and thread and maybe an 1/8th inch difference in length. They looked interchangeable to me. They are not! I had pulled the speed sensor and with one of the bolts in the wrong place the speed sensor could not be reinstalled. I burned 2 hours figuring this out and another hour fixing it.
Anyway, I'm 67 and I did this job by myself. I feel like I have been doing aerobics all day - should sleep good tonight. The car drives perfect. I stink of gear oil.
Old Oct 6, 2013 | 08:20 AM
lavoy1's Avatar
i went with the comp stage 4. think i might have broke my diff friday at the track so i think a how to change your diff video might be on the way lol.
Old Oct 6, 2013 | 08:33 AM
boostedwrx's Avatar
LOL no better time to get a built one I guess.
Old Oct 6, 2013 | 09:50 PM
xXANCHORMONXx's Avatar
Great job just did my 5th evo clutch last night. It's pretty straight forward exept for that reinstallation bit. I may try an engine hoist next time that way I can have it rolled back to clear the subframe.
Old Oct 7, 2013 | 12:15 AM
jason42003's Avatar
Just drop the subframe, I know it's counter-intuitive, but the amount of time you spend dropping the subframe actually pales in comparison to the time spent trying to finesse the trans out past it. At least in my experience it does and off topic Barnyb r u really in your 60's and not jus driving an evo but still working on it yourself. If you are u r my new hero haha.
Old Oct 7, 2013 | 01:07 AM
sktng22's Avatar
damn thats gonna cost a nice penny . but on the bright side more vids!
Old Oct 7, 2013 | 10:40 AM
lavoy1's Avatar
yeah diff is broken i have it apart. doing a how to video on how to replace your diff and in my case with a OEM LSD i ordered. will post video when done.
Old Oct 7, 2013 | 11:16 AM
boostedwrx's Avatar
For when its back together http://www.teamrip.com/transfer_case...tion_info.html
Old Oct 7, 2013 | 05:06 PM
barneyb's Avatar
When you're retired you need something to do to keep in shape. An Evo clutch job is a better workout than a home gym.
I was thinking of dropping the subframe. I put my mighty airwrench on the driver's side nut on the subframe and my mighty wrench tucked it's tail and ran.
So, here's what I did. First, I took a dremel to the long studs on the end of the transmission and made them much shorter. Then I pulled the control housing. Then I dropped the engine as much as I could (I was using an engine hanger and a hoist for the tranny) and finally I put the scissor jack that came with the car between the block and the subframe in front of the transfer case and moved the engine to the front about an inch. With that the install was pretty easy.
Alan Szabo Jr
Jun 16, 2015 03:09 PM
Randy321
Nov 18, 2012 03:26 PM
ralliartyz250
Feb 24, 2012 01:20 PM
sti_killa
Jan 6, 2008 02:24 PM
Quick Reply: video on how to change clutch in a evo 8
