Opinions on Rads?
Old Oct 5, 2013 | 07:41 PM
Nemaris's Avatar
Opinions on Rads?
I am looking around for a high performance rad that will be good for daily driving, but also small/slim enough for future turbo upgrades. What are your guys suggestions that won't break the bank?
Old Oct 5, 2013 | 08:24 PM
sktng22's Avatar
well the slim part is in the fan. if you looking to ever do a forward facing turbo or something huge your going to need a half rad http://www.mellonracing.com/index.ph...roducts_id=811 . a mishimoto full rad will work for anything else with stock fan and if needed to you could always buy a slim fan. they work and wont break the bank
Old Oct 5, 2013 | 09:15 PM
Nemaris's Avatar
so the half rad will work fine for daily driving? It's not just a short term racing type of thing? Also is a fan with a shroud worth it, or should I just get a fan? Thanks for the reply
Old Oct 5, 2013 | 09:23 PM
mitsubeastlee's Avatar
im 90% sure on purchasing a mishimoto full rad with fan shroud/ dual slim fan kit.
Old Oct 5, 2013 | 09:47 PM
sktng22's Avatar
your best bet honestly is probably a mishimoto full size rad and use the stock fan and shroud assembly it bolts right on. later on if you need a slim fan then get it
Old Oct 5, 2013 | 10:25 PM
SDevo13's Avatar
The mishimoto is really thick (much thicker than stock). I would suggest a cbrd radiator if you are ever thinking of pushing the space limits with a big turbo later on.
Old Oct 5, 2013 | 10:27 PM
sktng22's Avatar
hes asking for something that dosnt break the bank. anything from cbrd will break your bank and take your children
Old Oct 5, 2013 | 10:48 PM
Nemaris's Avatar
Yeah I checked out cbrd, looks like great stuff and a lot of people here have them it seems. If you guys think it is worth it, and a necessity for further upgrades to the turbo then I will get it. What about koyo? is anybody daily driving their half rad?
Old Oct 5, 2013 | 11:12 PM
sktng22's Avatar
koyo is good. yes some people drive with half rad. and what turbo do you really plan on going with because overall having a full rad is gonna be better on cooling and most full rads even stock with a slim fan can fit a pretty big turbo. im going with a 6262 precision and it fits fine with a full rad
Old Oct 5, 2013 | 11:20 PM
SDevo13's Avatar
I have a 6266 (AMS Kit) and a Mishimoto on my black car. Will be fine with a Mishimoto if you aren't going much bigger. You will need a upgraded (stiffer) front motor mount with a Mishi and a big turbo though. A stiffer front mount is a good idea in general, but absolutely necessary with a bigger turbo and a Mishi. Otherwise under heavy braking you will dent up/puncture your radiator. Just depends how big you are going turbo-wise. Haven't personally owned a koyo (on an evo) but they have had solid reviews. One word of caution on the Mishimotos: Some people (most) get lucky (like myself) and only ever need one. Some people end up with a 3rd replacement radiator that still leaks. Mishi replaces them, but it can be a lot of time/labor if you get unlucky.
Edit***I wouldn't recommend a half radiator on anything but a drag car***
Old Oct 6, 2013 | 10:14 AM
Nemaris's Avatar
Well it seems I'm on my way, I've got blox motor mounts and an in galls stiffy, so I should have a stiff enough mount. Im wanting to go for a v band setup with a ball bearing turbo. still unsure of the turbo I want though. I'm wanting to go from my 350 to 500 eventually.
Old Oct 6, 2013 | 10:50 AM
evoredy's Avatar
I have the CBRD slim radiator with their add-on slim fan. I retain my car's AC and condenser fan and the temps have NEVER budged in the Texas heat with the air conditioning on. Not just daily driving 15-20 miles, but Dallas traffic and all during a 120+ mile drive with mixed speeds. I even *minorly bent some fins on it during a manifold removal that might make Chad Block cry lol. I race my car at the track at least once a month to practice treeing and tuning. This might be the best non-power adder I have purchased. Well worth the money and it allows a lot of clearance for my GT35R.
Do NOT go half width for daily driving in the area of what I said above. You may get away with it for cooler environments.
Old Oct 7, 2013 | 07:51 AM
CBRD's Avatar
Building things one by one- and not outsourcing overseas for a sub par core does tend to bring our prices up
Our radiators arent a great profit margin product for us- They are more so a way for us to show people our attention to detail- and provide a superior product-
our 1" radiator was tested against 4 others about 4 years ago- beat them all in a major magazine- but they didnt publish the results because of the other companies who were paying for advertising in the magazine threatened to drop their ads- politics won- but our product out performed-
cb
Old Oct 7, 2013 | 07:52 AM
CBRD's Avatar
Thank you for your follow up!
our 1" radiators now have proprietary aluminum brackets for 1" fans etc- no more push through mounts-
cb
Old Oct 7, 2013 | 09:16 AM
gsrboi80's Avatar
Stock unit lasted me 140K. Car never had a cooling issue.
Unless you need the bling factor, EVO's really have no issues with cooling at all
Quick Reply: Opinions on Rads?
