Evo 8 transmission leak from driver's side
Alright, I recently put my new tranny in and it started leaking right off the bat. Initially it was a pretty decent amount coming from the driver's side. I took the axle back out and replaced the seal and the leak slowed but didn't stop. I tracked the leak down to a small hole thing with what looks like a ball bearing in it. Below is a pic I took of it on my old transmission. It's the upper one that is currently leaking.
What is this called? Is it some pressure release or something from the housing? Why would it be leaking and how do I fix it?
Thank you.
Thank you.
Well if it was me at work I'd start with heating the metal and tryto drive the ball in a little deeper. If it's still leaking and it's my car I'd brake clean the hell out of it and seal it with some high grade epoxy. If it was a customer car I'd replace the trans case. Don't really think there'd be many other options.
Just weld over it. Fill the hole with aluminum.
Just a comment. Yeah, this is aluminium and aluminium can be welded. But welded aluminium always warps. I welded a crack in the aluminium tub on my lawn mower and now one wheel is off of the ground. So, be cautious.
Is that a stamped aluminum tub? I've never had an issue with welding big cast pieces like this (specifically: engine cases for motorcycle and dirt bikes). And putting a dab of fill material over that hole is going to generate far less heat than welding up a crack that has some length to it. Best bet would be to use a TIG welder, and crank the amperage to get it heated as quickly as possible, that way the HAZ will be smaller. Also, on aluminum, it helps to have the ground as close to where you're welding as possible so current doesn't travel through the hole part. It helps reduce warping.
Thank you.
Thank you.
That's where the oil galley's are cross drilled to finger oil tinge bearings and fill the output shaft.. They then plug them with those *****.
Tommyfacekicker (Apr 10, 2018)
3deep
67
Aug 29, 2017 10:54 AM
aviseevuoptical
Feb 28, 2016 12:24 PM
