boost sputters under WOT
cant figure out what the problem is.. every time i boost it after like 10 psi a weird noise comes out the exhaust and i have major power loss..
i've tried it in every gear there all the same just sputters and goes no where.
put new plugs in gaped them to the right specs.. boost leak tested and just the throttle body seals are leaking. dont know if thats from it.
anyone else have a similar issue?
Sounds like exhaust leak. Mine was starting to smell the same under high boost (in my case, smelt like unburnt fuel when the hvac was set on fresh air). Turns out the twinscroll gasket and downpipe gasket were leaking. They also cause some boost fluctuations. Only way to test it is to put your hand nearby the turbo. Otherwise youll need to take it all apart.
It could be injector leak but you would smell gas under the hood. I would check it first to rule them out but my guess is turbo gaskets. Good luck
Do you have a cat on the car? what are you controlling boost with?
Here reply #22 has quite a few things for you to check. My guess is wastegate, and yes re-gap plugs to.024
https://www.evolutionm.net/forums/ev...an-12-psi.html
Absolute worst case will be to take off the turbo assembly to check if the gaskets are bad. Before that do a boost leak test if you havent already.
