early mitsubishi 3000gt rear diff on a evo 8 help
Hi guys, just wondering if anybody as ever fitted the earlier 91-93 rear diff off a twin turbo 3000gt to a evo? Its the smaller of the rear diffs that came on the 3000gt, its more of a rs sized diff and is a lsd diff with the same ratio as on a evo 8. Basically I want to know if it would be up to the job of drag racing like the rs rear diff is as I have one lying around, bearing in mind my car as in excess of 800bhp on pump fuel. Any help would be good thanks dave
Thanks johnbradley, you wouldnt happen to jnow where I could get a crown wheel and pinion in 3.307 ratio would you? As I have the casing and lsd already. Also need to get the hangers made to make it fit my evo 8
Thanks johnbradley, so what your saying is I can use the crown wheel and pinion out of the smaller diff to fit it in the bigger diff? The big diff I have which is the same casing as the ams one but its a 3.545 ratio, the little diff I have the ratio on that is 3.307 but obviously no good for drag. If your saying I can use the crown wheel and pinion out of the smaller diff to fit in the big diff then im almost home and dry :-)
Hi john, just took the covers off the diffs, the big diff the crown wheel is bolted to the diff with 10 bolts but the little diff the crown wheel is only bolted on by 8 bolts, so I think they might be different :-(
Nutjob
Jun 5, 2015 08:42 PM
Nutjob
Jun 5, 2015 07:35 PM
fq400dave
Oct 3, 2013 01:32 PM
