71hta question ..
Old Nov 22, 2013 | 04:19 PM
211Ratsbud's Avatar
71hta question ..
Did anyone buy it new from fp with the 9.0 housing like mentioned on their webpage? In have a 10.5 and I wanted to get a good idea of torque from a dyno graph and not speculation like 200 rpm sooner etc..
Old Nov 23, 2013 | 04:10 PM
slowsrt4:('s Avatar
I have the 10.5 hot side on mine I think I lost my dyno sheet but I made 362 tq @3666 rpm
Old Nov 26, 2013 | 12:02 AM
sparky's Avatar
I would try a 9.8cm hsg. That should reduce spoolup by a couple hundred RPM. The 9.0cm housing is just way restrictive on the top end. I ran a 9.0 on an OS Green for a bit but ended up pulling it off. I still have the thing under the bench, Ratty, if you wanna try it. But, 9.8 would be a better compromise, IMO w/o trading off as much top end.
EDIT: Sorry my bad. I had forgotten, but I think that the OS Green had a larger than stock turbine wheel, so my 9.0 hsg. is cut and won't work in conjunction with the 71 HTA's smaller, stock TD05H wheel....Duh
Regardless though. I would stay away from the 9.0 and just try the 9.8 instead.
Old Nov 26, 2013 | 12:28 AM
deylag's Avatar
Why does this turbo come with a 9.0 cm housing? If my memory serves me correctly, I have never seen it written explicitly like that before until now.
I would contact FP to confirm.
Old Nov 26, 2013 | 08:13 AM
nollij's Avatar
Similar to why the HKS turbo came with a 9.0 housing... response.
Old Nov 26, 2013 | 08:50 AM
211Ratsbud's Avatar
I'm just lookin to see where the 9.0 would put peak tq .
The 71 flows more than a os green I believe ..
Sparky do you know if you can buy new 9.8's?
Old Nov 26, 2013 | 04:02 PM
slowsrt4:('s Avatar
Contact FP and tell them you just want to buy the CHRA and that you will use your 10.5 hot side. Also get a Evo ix waste gate and j-pipe for the install if you are doing this on an viii
Old Nov 26, 2013 | 05:02 PM
211Ratsbud's Avatar
already have this turbo .. I also had an os fp white clipped.
The <10.5 housings are what I'm interested in for this turbo
Old Nov 27, 2013 | 07:42 AM
nollij's Avatar
FP has a couple 9.0 housings in stock but no 9.8 housings.
Old Nov 27, 2013 | 10:56 AM
211Ratsbud's Avatar
Does single flapper or dual flapper matter?
Raptord
Jun 5, 2016 07:11 PM
Mikey Likes It
Aug 15, 2014 02:51 AM
IX_MR
Oct 30, 2011 05:46 PM
PCToolsWiki
May 8, 2010 10:34 AM
Kerr
Jul 14, 2006 01:07 PM
Quick Reply: 71hta question ..
