Who runs a 156mm Rod and 94mm Stroke on a 4G63?
Registered User
Hey guys!
I need feedback from any of you guys running a 94mm Stroke Crank and 156mm Rods in a 4G63.
I was running the 94mm/156mm combo in a 4G64 block however I want to go back to a 4G63 Block.
Please chime in on your setups! I am very interested.
I will be running around 750whp
Thanks Guys
Thanks Guys
Doing the math on it, you would need a set of stroker pistons (6mm shorter) to keep from hitting the valves/head. Also, you will need an 85mm piston for the 4G63 for stock bore, the stock bore on a 64 is 86.5mm.
Registered User
Yes. CP makes an off the shelf piston, as does manly and maybe a few others. I really want the 85mm bore. More meat in the cylinders, as I plan to run high rpm/boost
Does anyone run this setup? It should be a mild stroker 2.l with an excellent 1.66 rs ratio
Registered User
With a 10:1 compression Piston, there should be plenty of material in there.
I know there are people out there using a similar piston. I guess we will see how it works out.
Stock LS7 pistons are very similar
I know someone who took a stock 63 and 64 and measured how much it took to bore them out until the coolant jacket showed, and 64 took a lot more boring to get there. And this also highlighted the weakest part of the cylinder (the bottom) where splits occur on the ultra high hp/boost cars.
R/TErnie
80
Jan 7, 2021 02:46 PM
gSx
Jun 3, 2014 05:14 PM
