what kind of coolant?
Originally posted by EvolvedfromaWRX
go to the dealer and pick some up lol. i was just there and i found out that they charge 21.25 for a bottle! and than they told me you can use anything.
With the preponderance of manufacturers moving toward a "long life" antifreeze, the combinations are numerous and possibly disasterous.
G11 is completely incompatible with G12. Dexcool is incompatible with "standard" antifreeze. Toyota uses it's own antifreeze. GM diesels use a nitrated version of Dexcool that is (you guessed it) not recommended for use with other types.
No doubt Mitsubishi has their own 'blend' of coolant, but how many of those bottles do you really need? And how much are you willing to pay to get a broken cooling system replaced if the two coolants are incompatible?
ferb!
I have seen a "global" antifreeze on the shelf. Don't know who makes it, but they claim it's compatable with all cars and will not harm your system.
Also, if your dealer's service dept is cool, they will top off your reservoir for free. Just ask. Hell, you paid over 30k for the car. What's the big deal.
As long as it does not contain any Alcohol you should be fine.
- re the water wetter ... remember it breaks down leading to an appearance similar to oil in your coolant...
This has scared the **** out of a lot of people......
Originally posted by snapb1
The owners manual says "long-life antifreeze coolant or an equivalent". I am in need of some today, it is after 6, and there isn't a dealer close to me. Anyone have any ideas as to what to use?!?
If you're just low, i would pop in just pure distilled water. As long as it's not a huge amount, you shouldn't dip below a 40/60 ratio. I pick this because it still has enough anti-foam and anti-corrosion additives, plus it provides a high enough boiling point for springtime operation.
I know it's repeated a lot, but water has a higher heat capacity than glycol. I have a few charts showing this relationship if anyone is interested in the engineering...
ferb!
