bushwaker tranny oils?
Old Dec 7, 2013 | 04:10 AM
mr evo7's Avatar
Just finished doing a bushwaker tranny ungrade.
What oils do I use in it.
I am in South Africa
We get redline oils (heavy and light shock)
Liqui moly oils
And oem oils (diaqueen)
Temp over here is very high. We can reach up to 45 degree
Car will mainly be used to street and drag
So need best oil to protect from those launches
Old Dec 7, 2013 | 07:04 AM
gsrboi80's Avatar
Call your transmission builder and use their recommendation only.
Old Dec 7, 2013 | 09:26 AM
bbong's Avatar
I use Amsoil 75-90 Manual Transmission and Transaxle Oil GL-4 in my Bushwacker, I read it's a recommended fluid by many members on here, if not then your next best bet would be OEM.
Old Dec 8, 2013 | 11:36 AM
mr evo7's Avatar
What do you guys think about redline heavy shock in the tranny and tcase
Old Dec 8, 2013 | 12:06 PM
wang4u's Avatar
It is a very good oil. Problem is it is meant for racing and frequent oil changes or serviced often. Here is what TRE recommends: http://www.teamrip.com/manual_transm...tion_info.html
For me, Amsoil. OEM has proven to break down between oil changes and come out darker and thinner than when it went in. Amsoil comes out exactly the same as it goes in. Therefore, I cannot recommend OEM to anyone, esp since you are seeing over 100 degrees F.
Old Dec 8, 2013 | 02:20 PM
mr evo7's Avatar
We don't get AMSOIL in South Africa. Basically my choices are redline heavy shock (my builder suggest this one)
Or oem diaqueen
Old Dec 8, 2013 | 03:31 PM
wang4u's Avatar
Then run the Redline oil, just change it more often than suggested. Or you could order a big order from Amsoil and have it shipped to you. Wont be cheap, but at least you know it will be the best.
Old Dec 8, 2013 | 06:49 PM
apagan01's Avatar
Amsoil I guess I would vote for since I use it... ; l
Old Dec 8, 2013 | 11:53 PM
mr evo7's Avatar
Redline heavy shock it is.
What is the change interval on this oil?
Old Dec 9, 2013 | 12:30 AM
LetsGetThisDone's Avatar
Do not put redline shock proof in the transmission. It's too slippery, and it's not designed to be used in transmissions synchronized, helical cut, manual transmissions. It is for racing dog boxes that get taken apart frequently, or differentials. If they have redline shock proof, they should redline MT90, run the MT90 or OEM diaqueen fluid.
Old Dec 9, 2013 | 08:03 AM
mr evo7's Avatar
Ok what do you guys think about running redline MT90. Or redline cocktail in main tranny. And redline heavy shock in the transfer case
Dmx3alo
May 26, 2017 12:06 PM
cangri1788
Lancer Tranny/Drivetrain Tech
Apr 22, 2017 12:33 AM
EVO_RYAN
For Sale - Cars For Sale
29
Aug 2, 2010 12:28 PM
Jeffs2006EVOIX
Nov 20, 2007 12:04 AM
Quick Reply: bushwaker tranny oils?
