Turbo for 500+whp
I'm not complaining by any means, simply pointing out what to exepct for a street driven car and these big turbo cars are usually mutually exclusive. a 2.4L bottom end would help spool and low and torque though.. ~350whp motors with 264 cams usually still remain completely streetable.. above that with out aftermarket ECUs and with bigger turbos expect less than adequate daily driven (low to mid rpm) usability.
Originally posted by RnR Racing
The works turbo is using the same turbo we are using a GT35R. It just uses a stock manifold unlike our tubular unit.
Also our kit made 395whp on 91 octane pump gas and 20psi.
Ron RnR or whoever. Ok so the HKS turbos are basically Garrett units? So how do the garrets perform at lower levels of boost (say 1.5bar)? What are they like for spool up (please give figures for boost/rpm)? Why are HKS units the tuners choice in Japan? By the way I am not dissing you in any way I just want answers.
OK, Garret units and HKS units use identical components, but HKS mixes and matches those components, and then you pay considerebly more for their name. Sometimes HKS is better and sometimes its worse then straight Garret stuff. If the tuner chooses to make their own combination using Garret parts then it will be the same quality of part.
HKS units in Japan? Well, Garret certainly does not sponsor very many Japanese Racecars, and I imagine HKS gets such a huge discount on importing Garret parts becuase of volume that buying Garret **** in Japan is not any cheaper. thats speculation, but Japanese people tend to like buying from Japanese companies.
RNR has there upgraded intercooler on their car, and they sell the whole kit, not just the turbo.
I was looking at there gt35r kit myself, good price, sick power. Out of all the ones I have seen this seems the best so far. There will be more coming out I am sure. I guess we will have to wait and see.
Shane
Shane
If you want a more powerful turbo, you are going to have to sacrifice turbo lag time. That's just how it works. So its not super streetable. But then again, if you're planning on 500+ whp, you're not expecting it to be a street car.
__NiTe__
__NiTe__
This will always be the case, and there will always be a compromise with all tuning. The AMS kit (https://www.evolutionm.net/forums/sh...threadid=69895 ) looks very good though. The GT32 offering around 500bhp with spool up only about 200rmps later than stock. Stick a stroker on there or run a high comp. ratio with good ignition and you will have standard spool up with 500bhp no problems. Who says you cant have power without driveability?
Originally posted by chuntington101
Or you could go for the HKS 3037s turbo. At its limits at 500whp from what I hear but will be better in the midrange and as a daily drive (quicker spool up than the 3240). Will run 2.0bar all day long and is very efficient at lower levels to.
545WHP on the HKS EVo 8.75 or 545HP?
a 450WHP setup that pulls from 3000 RPM to redline (+/- 8000 RPM ) would be astounding. Even better if around $2500. + 2500 in other pieces, pumps, injectors, cams, radiators, oil coolers, etc.
