Walbro fuel pumps. Failed right out of the box.
Old Mar 3, 2004, 08:56 AM
  #31
Eric Lyublinsky's Avatar
Originally posted by natedogg
A common upgrade on DSM's is rewiring the fuel pump. The stock wiring drops a lot of voltage. You can even here a loud pump like the walbro tone change up and down with the turn signal. I don't know if there is a similar problem with the EVO's, but it could be why you blew the relay. The pump was trying to draw too much current. You'd think you'd blow a fuse before the relay though...
See DSM wiring upgrade here...
http://www.vfaq.com/mods/pump-relay.html
Ya looks like the guys in the UK have bin doing this for a while does help not willing to do this on my own brand new car.
Eric
Old Mar 3, 2004, 09:01 AM
  #32
natedogg's Avatar
Yeah, I hear ya. Look at it this way though. You can use it as extra theft protection by wiring a hidden switch to disable the relay included in the wiring upgrade.
Old Mar 3, 2004, 09:11 AM
  #33
Let fix the problem first then I can worry about anther mod.
Old Apr 2, 2004, 10:02 AM
  #34
Coolguy949's Avatar
EvoJimbo,
If you have the stock ECU i dont see how a failing fuel pump would blow the engine. You'd either fuel cut if you were boosting, or the engine would just stall out. However, if you have a standalone (esp d jetro versions) it will probably end up running super lean then blow because of the lack of fuel and lack of sensors.
Old Apr 2, 2004, 10:13 AM
  #35
TRDHarrier's Avatar
i was planning to purchase the PE pumps. I shouldnt be needing one if I'm not running over 320whp right???
Old Apr 2, 2004, 10:20 AM
  #36
Grod101's Avatar
Originally posted by Coolguy949
EvoJimbo,
all it takes is a few seconds of no fuel to cause det. if this happens BANG! there goes a ring or a piston........ It is not hard to blow up a engine with running lean... even for a short time
Grip Master
32
Sep 18, 2015 01:09 PM
murlo26
14
Sep 27, 2012 10:38 PM
neonglh
Sep 25, 2010 07:06 AM
David Buschur
74
Jan 17, 2007 07:09 AM
Inn-Tune
42
Mar 11, 2006 01:32 PM
Quick Reply: Walbro fuel pumps. Failed right out of the box.
