RTM Racing Tank to Tank Fuel Line Kit
Hey guys,
About to order my Squash Performance double pumper setup for my build and was looking around for fuel feed and return lines, when I came across this company. Has anyone ever heard of RTM Racing? I see they are based out of Canada but I could only find one thread about them. This is the kit I'm looking at. Any help or feedback would be awesome!
https://www.rtmracing.com/xcart/prod...at=1016&page=1
I did, spoke to Andy and he got me the right fitting seeing as no one else knew what the right one was.
The hardest fitting to source is the one that is pushlock OEM to 6AN. Part # 644110 (blue) is what you need to go from the rear of the feed line to 6AN to go to your pump housing. You also need the adapter for the front of the OEM line to 6AN....
Russell-http://russellperformance.com/mc/ada...fuel-efi.shtml
Front fitting-http://www.extremepsi.com/store/prod...at=1559&page=1
The rest is just fittings and line. I used a 3/8" SS tubing and made the flares myself, I thought this was much safer than going with a braided line all the way underneath the car. Also it is much cheaper! See McMaster Carr for hardware and SS tubing.
Also, there is a possibility that I might have a Squash perf. double pumper (dual walbro 267) for sale in the near future. Used for about 200 miles.
No problem, these fittings are much cheaper than buying them from someone else.
I would map out the lines and see what fittings you will need to route it all the way you like. Maybe add a few extra fittings to be safe, you never want to end up waiting on a fitting since no one really stocks these locally.
It looks to be a solid kit. I just spent $250 on -6 parts to go from tank to rail. I'm using the factory return. The kit looks good though, looks to take all the guess work out of it. Haven't heard of RTM racing, but it looks like they are using quality parts.
bakuro117
Apr 25, 2017 06:34 AM
SR Concepts
Sep 13, 2015 03:19 PM
CrAnSwIcK
48
May 23, 2014 08:01 PM
