End All Crank Case Pressure and Catch Can Solution
I'm going to be building a large baffle catch can, with a 2 quart capacity or so. 4 inputs one Pcv, one valve cover, one dipstick and one off of the inspection hole.
I was going to add baffles as well and to have it vta until I found this.
Instead of vta I was thinking of using this and a check valve to burn off the oil vapor.
http://www.shop.speedunlimited.com/p...-in-steel.aspx
Has anyone done this?
The advatange to this is I won't have any oily vapor in my engine bay.
Any thoughts?
Thanks
Any thoughts?
Thanks
Looks good man! Make sure you get the stainless steel one if you have a SS TBE. I think I'm going to get this attached to the DP.
LMK if you want to order one. I can get you a pretty good price.
It did not work on my setup and did not pull vacuum at WOT. Using a one way check valve in the system the block generated 2psi of positive pressure vs ~0psi using the turbo inlet. I will go back and log the port directly without one way valve, but I am not holding my breath.
It looks like a 3 inch exhaust as well, if maybe a 3.5 inch would have a lower positive pressure I'm guessing.
What did you end up doing?
This is conflicting Becuase I did want to try this but this would have been a big let down if it did not work.
I was going to run it right after the last o2 sensor on the catback to avoid contamination, although I don't know if there'd be a differnce.
2006GSR
Apr 8, 2016 07:46 PM
TSiAWD666
Sep 24, 2013 11:58 AM
johnnnyjeans
Aug 17, 2012 11:16 AM
