From a 2.3 to a 2.4 ----> Spool difference?
I would only switch if the 2.3 fails and takes out the block. If you over bore the 2.3 to 86.5mm it is identical displacement just shorter/lighter pistons. Both have advantages and disadvantages. What you end up with is usually decided not by goals but by situation such as availability of a core block. Only benefit to a 2.4 block for you is slightly longer rods on a 2.4LR but there are a few issues with install of a 2.4 I wouldn't swap from a functioning 2.3.
I've seen a few builders, including Buschur, say more than once that they've never met a 2.4 that they liked. What are they not liking about these motors that other builders like those at English, don't seem to mind?
apeximprt2nr
11
Jan 16, 2009 07:49 PM
blackevo110
15
Jul 18, 2007 11:49 AM
