3rd and 4th Gear Grinding
Hi so I have a 05 evo 8 roughly 108k miles on the engine. I have noticed that there is a harsh grind when going from 3rd to 4th and I dont know what the problem is. At first I thought it was the clutch so I got an Exedy twin disk and replaced the stock one. This was NOT the problem. After talking to some people they said it my be the syncro's but I do not want to replace that and have it not be the case. Any help would be appreciated, the car is almost bone stock besides the clutch, intercooler and intake. Thanks in advance
-Justin
-Justin
If all the other gears shift fine and the clutch is adjusted properly then the transmission will need to be pulled apart. Sounds like it will need syncros and the gears inspected at the very least. Once repaired and installed I would recommend running it slightly overfull.
You can also send it to TRE/SHEP/JACKS. They can completely go thru your transmission for 1500+.
I'd also recommend a fresh clutch when it goes back together. The Comp stg 2 is pretty hard to beat for a daily driver /weekend warrior.
ArchieBabes
17
Feb 16, 2013 06:11 PM
miller121mx
10
Oct 17, 2010 04:32 AM
