Front 02 sensor clip on engine harness broke
Like title says, the front 02 sensor clip/plug on engine harness broke. The guts in the plug cracked and the wires came out. I need help with solutions, how could I find another connector or how do I hard wire it back to the front 02 sensor? The 02 sensor clip from the 02 housing is fine. Hope this doesn't confuse anyone
Thanks for the help, but 02 sensor and plug is fine. My problem is the clip it plugs into on the engine harness. That one is broke. Unless the Bosch universal has both female and male plugs?
??? What do you mean? The guts that hold the wires off the engine harness broke. The wires and pins are exposed. The easiest way to fix it would be to buy another harness and cut the clip off. But that's a lot of money. I was just wondering if I could hardwire it to the 02 sensor. But I don't know which wires from the harness go to the sensor.
GT35MR
Aug 17, 2015 03:44 AM
XstormtrooperX
10
Jun 1, 2012 03:24 PM
Dan@Assaultech
55
May 29, 2012 09:24 AM
ottoman
11
Feb 28, 2012 12:26 PM
