Rebuild rear diff or send it off?
I have a 05 evo 8 & the rear gear set it shot! broke teeth off both, but the rear diff itself looks good. I was planning on getting the hks 4.11 gear set or should i sty with stock? i was also going to go head and replace the gaskets and bearing while it was out, and also rearrange the disc. So would i be better off ordering the parts and doing it myself, or sending it off to TRE, shep, or jacks? thanks in advance!! Dalton
im a bit confused but the 4.11 Final drive would be in your tranmission, not anything to do with your rear.. you can easily find a complete rear for $250+ used. if you definitely want to make it stronger then im sure an expert like TRE would know the ways to getting you there, since replacing parts will make it the same as it was. which these things are pretty stout, sorry to hear you had issues.
oh my bad on the gear set thing, i was told you you could change that haha I have emailed TRE bout week go & still have not gotten a answer but i know he stays busy.
Although if your ring and pinion are shot, he might make you get a new set, which is around $550-$600 for the set. Buying a used rear diff somewhere, sending that unit in and selling the LSD as a whole to someone might be cheaper to do.
ill keep emailing him, ive been looking for a new gear set but really havent found anything, but ill look for a used rear end try to work out a deal. thanks everyone! im ready to get it back on the road since the v8 guys re doggin me right now
lucky13evo
28
Jul 23, 2011 02:17 PM
boostinscooby
Aug 18, 2009 06:08 PM
