Need some help finding a connector
Looking for the connector that is sold with the walbro F90000262 (400), basically the female side of a walbro 255 or stock fuel pump... I need one to build a custom plug and play harness for a Walbro F90000267 (450). I really don't wanna have to get one shipped from Austrailia, looking for one locally but coming up empty... Here is a pic fro reference...
Mrfred... i need the female connector pigtail that is identical to the power connector that is physically molded into a walbro 255 or stock evo pump... that way I can plug the oem wiring directly into a walbro 450 instead of having to cut and solder everything...
The connector pictured above is exactly what I need but dont wanna order it from out of country unless I have to...
Since the wires are molded into the W450, and the plug on the end of the wires is completely different than the plug you are describing, how is that going to help? If you don't want to cut any wires, then the mating plug for the W450 is needed as well as a plug that will mate with the fuel pump carrier. I know where to get both of those.
I was going to do one of two things...
1. Cutting the connector coming off the 450 pump and repin with the connector I pictured above (what I would like to do)
2. Getting the mating connector for the 450, and making an adapter harness to the connector I pictured above.
Either way I want to avoid soldering wires that are going to be submerged in fuel...
Where can I get the connector that will mate with the fuel pump housing is really what I am asking LOL...
sameeeer45
33
Sep 22, 2017 04:05 AM
joseari
May 5, 2017 02:32 PM
Ted B
Feb 20, 2016 04:43 AM
nikush
Nov 24, 2015 11:27 PM
