How to fix a leaky V-band?
Old Feb 26, 2014 | 06:38 AM
Silvermike's Avatar
Hey guys,
I have an ETS v-band manifold to a precision turbo and I'm getting a small leak on the turbo inlet. (worst place ever!)
My research showed that the flanges maybe warped. Is it possible to use those V-band gaskets to help it seal? Or some sort of copper gasket paste?
Old Mar 2, 2014 | 09:47 AM
Joshthree6three's Avatar
I would pm ETS after putting a straight edge over each surface and confirming the warp
Old Mar 2, 2014 | 10:09 AM
BluEVOIX's Avatar
I prefer to put "interlocking lip". Basically the v bands would look like this:
___|__ |______
___ __ ______
So the left vband has a lip that sticks out and slides into the right vband.
Sometimes the exhaust piping is 3" Outer Dieameter and Vband is 3" Inner Diameter . In that case all you have to do is grab a 3" outer diameter pipe. Cut a section out that can slide inside both ends of the Vband and that will seal it. No welding needed.
Example:
___| |___
________| ______ |____________
________ ______ ____________
|___ ___|
Below pic is MAPerofrmance 3" o2 housing. Notice the o2 housing vband has a lip that sticks out and it will slide into the downpipe vband. I had there o2 housing before. Loved how they made this interlock. From observation a lone, they basically slid over the vband and left a little (maybe half inch) of the pipe protrude and welded in place. When the two halfs (o2 and downpipe) mate, they create a smooth transition.
Old Mar 2, 2014 | 10:12 AM
BluEVOIX's Avatar
You could also try using this:
http://store.034motorsport.com/v-ban...-gasket-3.html
or
Maybe even take a copper sheet and cutout a DIY gasket .
Locdizzel
Jun 8, 2015 02:09 PM
nollij
15
Dec 30, 2014 09:33 AM
TopLevelPerformance
Dec 29, 2014 11:11 AM
TopLevelPerformance
Dec 22, 2014 02:27 PM
steven121
May 22, 2014 01:45 AM
Quick Reply: How to fix a leaky V-band?
