3" or 4" intake, going SD on HKS 7460 Stock Frame Turbo
Guys
I am going SD: should I stay with 3" or upgrade to 4" intake, on HKS 7460 turbo (Stock frame)?
Thanks
I cannot find comparison to show dyno results between using 3" and 4", if any advantage.
Rather stay 3", to maintain the AEM Carb Legal AEM intake pipe.
Thanks
Wingless: is that HKS turbo in there? What size inlet?
94AWD, Mychailo,
Thanks guys.
May I ask specifically: technically its better to use 4", we are talking about gaining few % over what SD on 3" will do...or we are talking about ?
Help me out: I have this nice Carb Legal AEM intake, 3", newly installed.
I am limited to ~450whp on Mustang Dyno on E85. Maybe less.
Even though I am an engineer, and based on science I normally use the choke is at the choke, not upstream, there is more to the turbo/Internal Combustion science...
So maybe you can offer me your experience and also have you seen any testing?
Mychailo,
I know that Aaron at ER tested different inlet sizes...but I don't know the results nor what system was it: if it was a 3582 than its totally different than HKS 7460. But if it was an FP Green, we are talking valid comparison.
May also throw in another Q: new FP Green Stainless (non-twin scroll) housing with external waste gate. With FP, and others constantly coming out with new detail-upgrades (not sure improvements, but changes/upgrades)...we can spend $$$
So new FP SST housing requires new downpipe.
Do you see realistic improvement on FP Green from this "upgrade": what improvement, how much?
I am continuously monitoring the Stock_Frame medium size turbos, FP Green, FP Red, BBK-B.
I just spotted Zhong posted a more complete dyno-numbers done at FFTec (where i also get tuned) of his BBK-B on E85 on Buschur 2.3RPM motor 10:1. The spool is impressive on dyno, even though he feedback is less flattering - Zhong suggests its laggy on bottom, but once spooled it hauls.
I know based on his experience BBK-B is 450whp on MD turbo on Track-Tune, and 500whp turbo on Street-Queen tune. And on E85 at least spools well.
So many questions..
Hit me back please.
Want to get the SD sorted in optimal fashion.
94AWD, Mychailo,
Thanks guys.
Mychailo,
So many questions..
Hit me back please.
Thoroughly enjoying my SD set-up on stock turbo tuned by ER with a 3" intake.
If I am not mistaken ER found significant gains on a stock turbo with a 4" SD intake in combination with an FP 84mm housing.
Would be interesting to find out if there are gains for the stock compressor housing by going to 4". Given where it is located, eg upstream of turbo - apart from possible packaging issues - it cannot do any harm except to your wallet.
94AWD, Mychailo,
Thanks guys.
Mychailo,
So many questions..
Hit me back please.
94AWD, Mychailo,
Thanks guys.
Mychailo,
So many questions..
Hit me back please.
I have to see this ER test...and yes, I can totally see how an 84mm cover which is 3.3" (25.4mm in 1"), will benefit form 4" as using 3" would require a reducer.
But an HKS...maybe ER knows, all it took is one Evo 9 turbo or original FP Green with 64mm (2.5") cover to test.
I agree it cannot hurt.
I see a possibility if you have a 4" that it acts sort of like air-reservoir similar to intake manifold volume....vs displacement of each stroke.
If somebody has some concrete links to Dyno tests or experiences, please chime in
I asked this very question before here figuring Tom would have deltaPower numbers but no such luck.
https://www.evolutionm.net/forums/ve...ch-intake.html
I'd be more concerned with the available filter area rather than inlet diameter. Often it seems people are using ridiculously small filters on the end of their inlet pipes. If you notice in Tom's ad above, he's got a HUGE filter that's probably reducing all the head loss. My wager is that for your 7460 450whp application you'd see little gain between 3" & 4" piping given the same (adequate) filter. Plus it'll probably be easier to package that intake into a cold-air box.
I wish I had test data for you but I'm not on SD yet.
Thanks
AEM intake filter is big
And I trust not a big restriction, but now am speaking laymans language- because I don't know what is big, small, concrete numbers
I need to present minimal restriction at 50+lb of air flow rate.
I hope Tom or Aaron see the post and add their experience
Hi Iveca ! (long time no talks)
Please find here picture of my 3'' (80mm outside diam.) intake pipe between the HKS turbo and Monster/Japan carbon air box. Of course you know it is also on a VI TME..
Daniel
Is that you?
The SD is not for TME, its for my 8.
Interestingly, I also have Monster air box, and ralliart hard-pipes on TME.
I decided to start with 3" intake, and at some future time I can test a 4" if any doubt in the decision.
I'll report findings.
Ivica
Is that you?
Ivica
dmotors
May 9, 2011 10:38 AM
Sean@Iveytune
Jan 10, 2011 11:41 AM
