Balance shaft belt timing help
Thanks for your help. I see the mark. Is it like the oil pump shaft where it needs to be on the correct rotation or can I just line up the mark. Thank you
from lost himself.
You don't need to put a screwdriver in the balance shaft inspection hole. Just twist the oil sprocket clockwise or counter clockwise. If it falls towards the timing mark then the balance shaft is fine, if it falls away from the timing mark then the balance shaft is 180 out
alexc
Jun 16, 2015 11:20 AM
EvO-LOui
Feb 18, 2015 10:38 AM
