Oil pump modifications for big horsepower and high revs
It doesn't seem to be public knowledge or common knowledge, but I'm curious who does what? Are the straight cut gears the only way to go? Can the 90 DSM oil pump gears work in an evo oil pump? Do the helical gears still work fine at 9000+ rpm and 800+hp?
Does anyone do any other modifications to the oil pump itself?
Do evos port the OFH like DSMs?
I did a bunch of searching and didn't find any decent information, not sure if it isn't out there or my search terms weren't proper
Thanks guys
Thanks guys
Bumping this because I too am curious as to what people are doing. Do the straight cut oil pump gears work for the evo oil pump? What other modificationa are suggested for 9k rpm and high hp evos?
https://www.evolutionm.net/forums/ve...pump-gear.html
Here is one option
Here is one option
straight cut gears do nothing but ad noise. side load on gears is not the problem. its the small shaft on oil pump drive that gets side loaded into the input housing. stiff valve springs. lightweight clutch assemblies, over tightened belts and possibly kevlar belts are most of the problem. a good polish and debur of the pump is about the best thing out to prevent. machined down balance shaft is waste of money as well and does zero to prevent.
Also I know it's common knowledge people also remove to balance shaft and try to find solutions to help eliminate the stub shaft options to get the most out of their oil pump (and assembly). However over time its been found out that it does cause premature wear with motor and clutch assemblies.
The stock oil pump is really good
I've taken it that high on previous Evos
So are you saying the oil pump won't hold up to 9k rpm pulls for very long?
Curious about the lightweight clutch assembly? Harmonics?
What I'm saying is for your driving the stock pump is fine for 9k
People that source alternate oil pumps are usually those at sustained 9k+ revs
Which is why I suggested previously that the stock unit is fine
I've been well above your revs an hp with a stock unit and had no failures
