Running Lean after Turbo Install
Old Mar 17, 2014 | 05:57 AM
12WWGSR91's Avatar
Hey guys so i ran into some trouble. My car was tuned before with only tbe, intake piping, walbro 255 and stock evo 8 turbo. Yesteraday we installed a bbk full ported, megan 02 housing and ported manifold.
After we installed it the car would idle really lean. It doesnt even say a number on my aem wide band its reads (---). Normal driving it would be around 15.5 to 16.
We rechecked all the lines and everything was good. Does anyone have any idea?
Was wondering if this is normal and that i need a retune?
Old Mar 17, 2014 | 08:07 AM
boostleak's Avatar
Mine did this when I had a vacuum leak. do a boostleak test and check for exhaust leaks also.
Old Mar 17, 2014 | 09:52 AM
superkizuna's Avatar
OMG, I have the same exact issue! I'll let you know what I run into during troubleshooting.
Old Mar 17, 2014 | 11:55 AM
12WWGSR91's Avatar
Bro. Dont waste money on a new o2 sensor i already bought a new one and it does the same thing.
Old Mar 17, 2014 | 12:43 PM
damnit, did you go through ALL the fittings and couplers and stuff?
Old Mar 17, 2014 | 03:48 PM
ReaperX's Avatar
You both probably have an exhaust leat. Did you reuse and gaskets and did you get new ones? Check to make sure all your connections are torqued appropriately.
Old Mar 17, 2014 | 06:09 PM
12WWGSR91's Avatar
Solved. It was an exhaust leak. It was a small exhaust leak.
Old Mar 17, 2014 | 06:42 PM
ReaperX's Avatar
More often than not a very lean wideband reading at idle and normal at cruise points to an exhaust leak. Glad you found it!
Old Mar 17, 2014 | 09:25 PM
12WWGSR91's Avatar
Thanks for your help man.
El Boricua
AEM EMS
11
Apr 13, 2015 06:31 AM
mrm95
Nov 1, 2014 09:30 AM
12WWGSR91
39
Jun 14, 2014 07:01 AM
Graphic
Jun 5, 2014 05:05 PM
superkizuna
30
Mar 19, 2014 08:09 PM
Quick Reply: Running Lean after Turbo Install
