GTX3582r Compressorwheel
Hey,
Has anyone any real experience with the aftermarket compressorwheels for the gtx35?
Do they really spool faster and have better airflow?
Currently got an gtx3576 that im going to upgrade to a gtx3582 and want the best possible wheel.
Oh I just noticed that... So FP take the normal GT3582 and alter the compressor wheel on that? I just did a quick comparison and there doesn't seem to be much difference between them. So.. what do FP actually do..
The GTX3582R is a stout beast - definitely much more lag than the HTA3582 but then also a good amount more flow
Completely different compressor wheel - same as GT versus GTX. The FP's version only provides a bit of a flow improvement over the normal GT3582R but a lot better spool, or a reasonable flow improvement over a GTX3576R with similar response.
Im looking to upgrade the one i have, to an 62+mm compressor. What is the best? The titanium ones are stronger but heavier and i would like to keep as much spool as possible, and get as much air as possible. 79 pounds at 2.2 bar with great spool is my wish.
The GTX3576R may have a 58mm inducer, but only has a 76.6 exducer vs. the GT3582HTA which still has 82mm exducer. that additional rotational inertia given for that compressor wheel does indeed change behavior in the midrange, more than the HTA. Top end power, the GTX3576R takes a few more psi to do the same thing, but is limited to about 650whp while the HTA is a bit more effective than that if the goal is to reach upper end power..
I have both, and yeah, there's a difference alright. but mainly for circuit use.
In your case, there is no "best" as there are a lot of options out there, but I'd stay with the Garrett-based companies for best integration for the need.
turbo addict
Jan 22, 2017 11:18 AM
WTB[West]: GTX3576r, or GTX3582r
mygsx
Jan 31, 2016 08:04 PM
evoxisking
Oct 18, 2015 03:37 PM
