Evo IX - Hole in Intake Manifold?
Old Apr 6, 2014 | 03:39 PM
ehall20's Avatar
I've circled the hole in red (MS Paint FTW)
Just noticed this the other day, there's a small (approximately tic-tac sized) hole in my intake manifold. It hasn't caused any noticeable drivability issues so far. A guy I work with (mechanic, but no specific experience with Evo's) said it wasn't a problem because the hole is in the webbing of the manifold, but I wanted a second opinion from you guys.
Is this something that needs to be addressed? And If so, will slapping some JB Weld on it be sufficient, or will I need to actually weld it shut? Thanks in advance.
Old Apr 6, 2014 | 06:49 PM
SW20Mike's Avatar
Veteran: Air Force
Looks like it is between the runners, so wouldn't think it would be an issue. Just do a boost leak test and see if any air comes out, if it does put some JB weld on there.
Old Apr 6, 2014 | 10:22 PM
xXANCHORMONXx's Avatar
Extra material from casting, your good.
Old Apr 7, 2014 | 01:17 AM
ehall20's Avatar
Thanks guys, just had to be sure.
Old Apr 7, 2014 | 07:19 AM
cfdfireman1's Avatar
If you have any doubt with the car running spray a little carb or brake cleaner in the area and see if it changes RPM at all.
Old Apr 7, 2014 | 07:28 AM
Ev0ikon's Avatar
Yay for light-weight manifold. Must be a Race Car!
Jmills
Apr 11, 2017 09:33 AM
seven10
Feb 28, 2016 12:33 AM
Jmills
35
Jan 21, 2016 12:08 PM
OverBoostedEvo
For Sale - Part Outs
Jul 15, 2015 11:20 AM
mrwickd123
Sep 13, 2014 12:44 PM
