Tranny issues
Tranny issues
About a week ago my dad was driving my evo 9 mr, and he was about to go around a turn so he pushed the clutch in to downshift. He said the pedal dropped to the floor and stayed there. So he pulled it back up with his foot, and the pedal is like halfway up from the floor and will not move down. I checked all over for fluid leaks and found none. The slave cylinder operates properly. So I figured I have issues inside of the bell housing. The last few days I've been working to get the transmission out. This morning I pulled the access hole to disconnect the the throw out bearing. But it looked a little odd to me. It looks like some type of seal is in between the TOB and the wedge collar, and the wedge collar looks pretty depressed. Is this normal? Any help is appreciated, thanks!!
Honestly man I have no clue. This is my first evo and I've only had it for a few months. Idk too much about these cars yet. It looks to me like the internals of the TOB came apart from the metal housing and are stuck up against the pressure plate
Get yourself a new TOB. Do yourself a favor while you're on it, and get yourself a clutch fork stop and an ACT Monoloc for added safety.
I don't think that this issue is because you don't have an ACT Monoloc or a clutch fork stop installed, but always be one step ahead.
From the "shiny" area of the retainer clip that sticks out from the clutch, I would guess you have the Exedy retainer clip, which should be replaced with the ACT Monoloc I mentioned on my previous post.
Ok another question, how the hell am I supposed to disconnect the TOB so I can pull the transmission? I looked up the how to, but my TOB won't even get close to the wedge collar. Is it already released? The clutch fork is all the way towards the passenger side.
If not jam a screwdriver up between the clip and TOB and pus of the fork with your hand to try and get them to separate. If that doesnt work, rotate the engine while doing the same procedures listed before via crank pulley and ive known that to work on the real stuck SOB's sometimes. Worse case scenario os to go in from fork and undo all bolts holding PPlate to flywheel then deal with it once tranny is out. Hope all goes well
So I pulled the trans today and my TOB is done. So I'm going to order a new TOB, an act monoloc and a clutch fork stop. Only question is do I have to replace the pressure plate to use the act monoloc? I read in a couple of threads that you do and don't. Let me know, thanks
